UMI F-Body Tunnel Brace Mounted Torque Arm
Does anybody have a lowered T/A with the UMI 1993 - 2002 GM F-Body Tunnel Brace Mounted Torque Arm w/ Upper Driveshaft safety loop for long tube header set-up? I was wondering if there was any issues with the torque arm or anything else being too low because it is on a lowered car?
On the other hand I was thinking of putting spohn crossmember mounted adj. torque arm for long tubes and was wondering if anybody has had any clearance problems with them?
Last edited by mavedawg04; 12-04-2007 at 06:10 PM. Reason: I don't know which one to buy.
Hello,
Both our unit and the Spohn unit will reduce ground clearance on a lowered car and if I remember correctly ours will tuck up slightly higher. If the car isn't slammed to the ground you will be ok.. it will be the lowest point of the car but shouldn't be a issue. I wouldn't recommend it for a kit like the Eibach Sportlines or similar height.
If I can help anymore please ask. Thank you!
Ryan
Ryan
I bought the Spohn tunnel mounted arm for long tubes several years ago, When I lowered last year tt was too low and scrapped a lot. I bought the straight cross brace (supposedly for cars without long tubes) with the DS safety loop and just swapped it with the other one. Plenty of clearance and regained my ground clearance. You'll just have to make sure your exhaust is located properly. I'm running a 3 inch Y-pipe into a 3 inch I-pipe. It all fits fine.
Thank you!
Ryan
Ryan,
Your link doesn't work for me, but I want to buy one of your heavy duty tunnel braces with the DS loop. My torque mounts to my trans, so I don't need that option. And I can't get to them on your website by searching. Can you help me? Thanks!
Mark
Mark
Mark, Sorry about that. Try the link below, the last (4) are what you would be looking for. If you have any questions please ask. Thanks!
http://www.umiperformance.com/produc...ategory_id=130
LS1TECH Sponsor
Mark,
I'm going to talk to Ryan about this when he gets back from PRI. I think what Mark is after is just a DSL. Basically just the brace and loop from a TA setup, but he has a TA already.
Ryan,
Marlena has the message about this, call me!
Ryan,
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Mark
