Pics of camaros w/ sportline springs
Anyone have pics of camaros w/ sportline springs i'd like to see exactly how low it really is. Thanks
Customizing Director
Well as of right now I do not have headers, but when I do decide to get a set I will probably get Mac mid's with the random tech cats (My car now with the LM and 3200 converter = loud). I know that I would not go with SLP lougtubes, their just wouldn't be enough clearance. As for the hookers, I've heard that they will be a little low, but you will have some clearance compared to SLP's.
If you want an idea of how low your car will sit, I measured my car from the black air damn in front of the car and I have 3inches off the ground.
![](http://rdvr.hypermart.net/camaro/02.jpg)
![](http://rdvr.hypermart.net/camaro/03.jpg)
![](http://rdvr.hypermart.net/camaro/04.jpg)
How do you work on your car when it is that low? Mine is not lowered and I can just barely fit the jack under the car, if its on a flat surface. I do have GFX but if I get it lowered I will have no way to work on it. I can't use ramps because they rub the GFX already, plus they are the
because I drove off the end of them and I'm scared to use them now.
Any ideas on how I can lower my car but retain drive and workability?
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Well my car is just as easy to work on lowered, it just takes a little extra work to actually get the car up
. I can't use the ramps because it will scrape bad, and then my wheels are just too wide to even fit on em
I use 2 jacks to get my car in the air. I take the 1st one (which is really low) and jack up one side of the car, then take #2 and replace #1 one with it to keep that side of the car in the air to give clearance for #1 to jack up the front end. Then I take #1 again and raise the whole front end by the frame. Then place jack stands, pull out #1 and then use #1 to jack up the rear by the rear axle.
*I do wish that I had once of those lifts built into the floor
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Or you could do it the ghetto way and drive the front or rear tires (or both) onto 2x4s or such...Just enough to get the jack under it.
I have to do that with mine, stock height, but my floor jack is kinda high...
