Advice on Sub Frame Connectors
What is the best recommended path based on your experiences?
Also looking at a new shock and spring setup to stop the dampening. After installing the SLP long tubes, I lost 1.5 inches of ground clearance and can barely switch lanes without scraping on the median lines. Any thoughts?
My SS: http://www.horsepowerfreaks.com/pict...t/Camaro/10210
Please keep us in mind for the subframe connectors as well. We offer both a 2-Point and 3-Point 100% bolt in style and both items do not reduce ground clearance. Please take a look at the links below and let me know if you have any questions.
www.umiperformance.com/2002
www.umiperformance.com/2004
Thank you!
Ryan
I assume the slp sfc listed above are the triangular style (more connecting points then the straight bar).
Also, when installing does anything have to get moved around with any of the styles out there? I ask because somewhere in a thread someone said "and you don't need to move the brake lines with this sfc".
Finally, what's a fair price for having them welded in?
Swayore, not trying to hijack your thread as I hope these questions fit the intent of your thread.
My opinion: Waist of money
I installed them before I installed my Pro-kit and bilsteins and after I got my C6s. I did notice a slight difference with stock, blown out shocks. After I got my springs and shocks, and after putting a few more miles on the car with the SFCs, I feel like they arent doing anything anymore. Plus, they reduce ground clearance and they are HEAVY. I dont think a bolt-in SFC was the way to go in the first place. Theres still going to be some movement with a bolt-in style. I have thought about having them welded in some day, but i doubt that will ever actually happen.
If you're curious and want to try it out for yourself and ignore the opinions of other (as I did), i wouldnt buy the overpriced SLP SFCs. Go with UMIs. I've heard a lot of good feedback about them. Theyre most likely going to be lighter and they dont reduce ground clearance so either way, youll be better off than me.
Thank you!
Ryan
Thank you!
Ryan
Thank you!
Ryan
Hope that helps!
Ryan
