Poly or rod?
Old Jan 23, 2008 | 12:25 PM
00HAWK#068's Avatar
Default Poly or rod?
Is it worth getting poly poly LCA's or should I got poly rod? The car is pretty much stock Firehawk mostly street driven with occasional trips to the track. Same question for the panhard rod.
Thanks
Old Jan 23, 2008 | 01:05 PM
Steve Burger's Avatar
LS1TECH Sponsor
If it's a street car stay poly.
Old Jan 23, 2008 | 01:12 PM
ReFtheMC's Avatar
Thanks
Old Jan 23, 2008 | 01:52 PM
robertbartsch's Avatar
poly poly would be a very bad choice.
A poly/rod end, however, would be much better since it allows the rod end to move in different directions as your rear differential flops on down the road.
Old Jan 23, 2008 | 02:05 PM
00HAWK#068's Avatar
So its a toss up?
Old Jan 23, 2008 | 03:09 PM
UMI Performance's Avatar
On a street car I would recommend the poly/poly set-up. They offer a equal to factory ride quality, are grease-able and require less maintenance.
On the panhard, we recommend a rod end on one end. The noise issues are minimal to none since they do not take the same load as the control arms. The rod end allows the rear end to move more freely with out binding.
If you need anymore help please ask. We have some great prices on both pieces.
Thank you!
Ryan
Old Jan 23, 2008 | 06:32 PM
INMY01TA's Avatar
I say get rod/rod if you can afford it.
Old Jan 23, 2008 | 07:43 PM
Black02SLPSS's Avatar
Thats what im going with.
Old Jan 24, 2008 | 08:26 AM
BlackBADaSS02's Avatar
I went with rod/rod.
Old Jan 24, 2008 | 12:58 PM
Randy WS6's Avatar
I have rod end and is quit
Old Jan 24, 2008 | 01:02 PM
JScamaro's Avatar
I would get the poly/rod on both the panhard and lower control arms.
Old Jan 24, 2008 | 02:09 PM
OK, so the rod/rod is the best for handling since the joints can move around as your suspension moves. Unfortunately, it can be noisy; right?
Anyway, I'm surprised about UMI's recommendation to go poly/poly.
What is your objective; handling, traction, road racing, 1/4 mile, street car? For example, I chose poly/rod since I want handling but I don't like too much noise over bumps.
Most LCA manufacturors discuss this in their catalog/web cite but it is good idea to ask anyway, I suppose.
Old Jan 24, 2008 | 02:16 PM
I do feel a poly/poly set-up will be the best for a street car. Sometimes adding certain items that aren't needed are over kill. Polyurethane binds, yes, but I do not feel a street car will push the vehicle to make it a issue.
Old Jan 24, 2008 | 11:53 PM
unSStoppable's Avatar
i wnent w/ poly /rod if that helps. She isnt daily driven but is not a track car by any means, just a baby
Old Jan 25, 2008 | 12:23 AM
transamws6_97's Avatar
my car is a daily driver and does see some time at the 1320 and every manufacturer ive talked to recommended poly/poly
on a side note i find it funny that the people actually making the suspension recommend one thing and everyone else says no
Old Jan 25, 2008 | 12:56 AM
hpjunky98's Avatar
Poly / Rod is what i went with... but i'm overly concerned with the thought of binding in a hard corner. Probably doesn't make all that much of a difference. If ride quality is your main concern, go with the Poly / Poly LCAs.
Old Jan 25, 2008 | 12:59 AM
speed_demon24's Avatar
No complaints with my rod/rod. They do transfer a little gear noise through the cabin, but other than that I don't even notice that they are there.
Old Jan 25, 2008 | 02:21 PM
00HAWK#068's Avatar
Thanks for all of your input, I think I will lean towards what Ryan from UMI suggests, it kinda makes sense.
Old Jan 25, 2008 | 07:23 PM
If I can help anymore please ask and I am happy to.
Thank you!
Ryan
Old Jan 28, 2008 | 01:45 PM
1FSTLS1's Avatar
This noise we are talking about can it be heard over the exhaust and stereo??
