need tq arm help ASAP!!!
between online stuff and my original install instructions, i'm confused as hell...so i'll simplify:
my driveshaft reads 4*+ and my torque arm is at 1*+.........UMI says i need -1* to -3*
how do i get there?
how do i get there?
I believe you're going to want to make sure the TA reads nearly the opposite of what you have now. For example: -2.0* at the flat spot on the TA and 0.0* on a flat spot on the driveshaft. Basically, you'll want the TA to be at about 2.0* LESS than the driveshaft.
I think I explained that right...
I just installed my umi ta yesterday, the part about the vehicle needing to be level isnt necessary. I had my rear on stands and my ds angle measured about 3-3.5* and the flat spot on the ta was about 5.5* just take the difference of the two, making sure your pinion points down a lil more compared to the ds. Does that make sense? Niether really need to be a perfect 0* like the instructions say, just take the difference.
ben.... the u need to put the angle finder on the bottom of the ta mount where it mounts to the rearend.. then adjust frm there. with having a six speed i would adjust it to -3... if it sets at 0 it will ruin your ujoints
edit..... its the pinion angle that u want not the angle of the ds or the ta.
LS1Tech Premium Sponsor
Like he said we have a video on our front web page that will demonstrate step by step how to check pinion angle.
www.bmrfabrication.com
I'm pretty sure the car has to be level, my angles changed when I jacked the front up level with the rear. From that point things got a lot simpler adjusting it. BMR's vid is pretty helpful, check it out.
yeah i got it. i kinda knew what i was doing to begin with, but the UMI instructions i have were kinda vague and threw me off as did some other people's advice on here.
i set the car up level with suspension loaded and turned the TA adjuster until it and the driveshaft were reading the same angle, i.e. i "zeroed" it out. then made the pinion 2* negative from the DS. i checked the crank pulley and it matched the DS, the car still has a little low RPM surge to it, so i'll go back and try 1* or 3* and see what happens.
thanks again for your help fellas
