94 Z28 Z06 Brakes to 98 TA & More Help!
Below is a link of all the mods on my current 94 Camaro. I found a 98 TA Conv. M6 w/ 17k white on white. I need the expertise from you guys on this site. How many parts can I take of the 94 Camaro and put them on the 98 TA and will those TA parts fit back on my 94 Z28?
https://ls1tech.com/forums/vehicles-sale-non-lsx-powered/856005-1994-b4c-police-20k-miles-mods-perfect-pics.html
Will these items swap out?
SLP 304 Stainless Steel Y pipe feeding into a 3" random tech high flow catalytic converter and a SLP factory 3" Super Sport 1 into 2 cat-back exhaust
Hurst short throw shifter
Energy suspension transmission mount
GM aluminum driveshaft
4:10 rear gears
T/A rear end girdle
Suspension
Front
-35mm hollow front sway bar (powder coated grey)
- Front sway bar energy suspension polyurethane bushings
-Bilstein front struts
-Eibach progressive lowing springs
-Kenny Bell Double Diamond sub frame connectors
Rear
-25mm solid rear sway bar (same grey powder coat)
- Rear sway bar energy suspension polyurethane bushings
-Front A-arm energy suspension polyurethane bushings
-Bilstein rear shocks
-Random technology adjustable cross member mounted torque arm (red)
-Hotchkiss pan hard bar (black)
-Hotchkiss boxed lower control arms with polyurethane bushings
Brakes (installed 7/07)
-C6 Z06 6 piston front calipers
-C6 Z06 4 piston rear calipers
-C6 Z06 front rotors
-Slotted/vented aftermarket rear rotors
- New ceramic pads
-Russell Stainless Steel Braided front/rear brake lines
-SLP line lock system plumed but not electrically hooked up or used
-C5 corvette master cylinder
Wheels (new 7-07)
-SSR competition HT2 front 5 spoke wheels with caps 18’X 9.5” 17'5 lbs ea.
-BF Goodrich G force KD front tire 265X35X18 (new 1/08 zero miles)
-SSR competition HT2 rear 5 spoke wheels with caps 18”X10.5” 19.5 lbs ea.
-BF Goodrich G force KD rear tire 295X35X18 (new 8/07 < 300 miles)
-ARP wheel studs at all four corners
4:10 rear gears
T/A rear end girdle
Suspension
Front
Rear
- New ceramic pads
Wheels (new 7-07)
