View Poll Results: Which Drag coilover should I get?
Voters: 18. You may not vote on this poll
Which Drag coil overs? Strange, HAL or QA1?
I am looking at getting drag race coil overs for the front of my car. Which do i need to get?
The local shop said to get QA1's because they could be rebuilt when they start leaking.
Are the Hals and the Strange shocks rebuildable??
Also, what pound spring should I run?
Almost Full weight car...........Battery in the back.....ABS delete........soon to have K-member
275, 300 or 325??
275, 300 or 325??
LS1TECH Sponsor
I would suggest AFCO if you have the $$. QA1 for a good value. You can get the QA1 in a single or double adjustable setup. For springs I would say you are on the fringe of 275 or 300. It depends on how much weight you pull from the car.
Let me know if I can help.
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
We have had great luck with the Strange units. One advantage the Strange units have over the QA1s is the Strange units use a standard 2 1/2" coilover spring which is readily available in multiple lengths and spring rates the QA1 units only have 3 options. Pricing on the double adjustable Strange coilovers is also better versus the QA1 pieces. We are a distributor for both lines so if you have any other comparison questions please feel free to ask.
