Lowering W/315s?
#41
The Strano springs drop the car approx 1.2 inches. Variations between cars won't be as wild as Eibachs. I have stock bumpstops still there.
I suppose if you remove your bumpstops, you may have more problems since you'd be allowing further suspension travel. But with the stock bumpstop there, stock springs or aftermarket, you are limited to the same compression travel.
#44
Location: Your girl's back door giving her the long stroke while you're at work
I've got a Eibach Pro-Kit and no isolators(heater hose mod) on my LT1 with 315/35/17s. I had to roll the fender lip and do a small amount of clearancing on the inner fenders.
