Lowering W/315s?
Old Feb 4, 2008 | 08:32 PM
M6 Swap's Avatar
Default Lowering W/315s?
hey guys iv got 315s in the rear and im thinking about lowering, but im worried about rubbing. is anyone running this setup, problems?
Old Feb 4, 2008 | 08:53 PM
djsanchez2's Avatar
Have 315's on the pro-kit. No issues after i got a adj. PHB and did the good ol' BFH mod to the rear fenderwells.
Old Feb 4, 2008 | 10:07 PM
DustinWS6's Avatar
BFH mod? My car is lowered with a pro kit and I should have some 315's on the way soon. I already have a PHB on the car
Edit: Big ******* hammer mod...lol
Old Feb 5, 2008 | 06:47 PM
M6 Swap's Avatar
hey sanchez who makes the pro kit? is that strano or eibach?how much
Old Feb 5, 2008 | 06:51 PM
RareBreed0295's Avatar
Its eibach...
Old Feb 5, 2008 | 07:38 PM
M6 Swap's Avatar
which is better?strano, eibach, any other brands?
Old Feb 5, 2008 | 07:58 PM
TXZ28LS1's Avatar
id look into bmr or hotchkis springs
Old Feb 5, 2008 | 08:05 PM
95 Z28's Avatar
Another prokit here....I've got 315 BFG dr's out back and NO adjustable panhard. Doesn't rub during everyday driving, but I am planning on getting a adjustable panhard, eventually
Old Feb 5, 2008 | 08:10 PM
Benner's Avatar
Same here except I can sit the rear down on the tires if I hit the gas to hard. That's mostly cause of my shocks though.
Old Feb 5, 2008 | 08:16 PM
2QUIK4U's Avatar
I have 315s on my car and I had the Pro-kit before and switched to Strano springs. I would never go back. The Strano springs are way better than the Eibach springs.
Old Feb 5, 2008 | 09:00 PM
DustinWS6's Avatar
Hopefully my 315's will fit without any issues
Old Feb 5, 2008 | 09:10 PM
unSStoppable's Avatar
any of you guys roll your fenders?
Old Feb 5, 2008 | 09:38 PM
NufNuffZ28's Avatar
I have 315's and pretty low. I have an adjustible PHR, removed the bumpstops and rolled the fenders. The hit NOTHING NOW! They were hitting the fenders before they were rolled...
Old Feb 5, 2008 | 09:53 PM
M6 Swap's Avatar
does lowering hinder the ride quality at all? i mean i want the best spring out there, cost really isnt an issue when it comes to quality, for me at least. thanks for all the input guys
Old Feb 5, 2008 | 10:19 PM
Stranos...just purchased a set..
Old Feb 5, 2008 | 10:50 PM
hpjunky98's Avatar
Another vote for strano springs. stance in my sig...
Old Feb 5, 2008 | 11:11 PM
infamous ss's Avatar
i rolled my fenders when i put my 315's, no rubbing at all. my problem is traction and i have all the suspension mods, i spin 1,2, and 3rd.... but no rubbing
Old Feb 5, 2008 | 11:12 PM
Detoxx03's Avatar
Strano springs
Old Feb 6, 2008 | 09:04 AM
Ryanmgaspard's Avatar
I have Sumitomo 315's. Before I lowered, I had to lightly beat the inner fenders and cut the bumpstop out. It did not rub anything with people in the backseat then.
When I got lowered and removed the rear isolator, the rear tires hit the fender lip on hard bumps or when people were in the back seat. Also, I had to re-hammer the inner wells because they rubbed again and rolled the inner fender lip. Yes, I have a double adj BMR panhard rod as well. Now I have zero issus with or without people in the backseat.
If you get an adjustable shock like the Koni's then you can make adjustments to soften the ride. If you wanna get lowered, it should be because you want it to perform better, a little comfort will be sacrificed. I have my front shocks on 4 from firm and the rear of full soft. Louisiana has horrible roads and my car feels like one solid piece of metal. Back home in NC is great. No bumps, handles awesome, couldn't be happier. Sam is the man though.
Old Feb 6, 2008 | 09:36 AM
RsSean's Avatar
I have 315 35 17's on OE concepts Zr1 wheels I have the problem of rubbing the inner fender. My bump stops are removed. I want to say the off set is 52 mm, but don't quote me on that. I belive If I lower with 2 inch spring the monster tires will rub both the rear quarter and the inner fender. Right now I have 1/4 inch spacer to get the tire off the inner fender. Any one with help? How much does the ADJ. panhard bar actually do.
