LS1 to C5 brakes worth it?
I want honest opinions please. Ok,I have already upgraded fron the LT1 brakes and its better ;however, I want to know if upgrading to the C5's are worth it or should I just pay more for Baer,ssbc,wilowood,ect...?
My opinion is yes and not just because we sell the kits.
When going from the LT1 brakes to C5 there is a larger difference then the LS1 to C5 but still a noticeable difference.
The nice thing about the C5 upgrade over the other kits is- The C5 brake parts are readily available almost anywhere include parts stores. The rotor and pad options are high too, meaning you do not need to stick with a certain rotor or pad.
If you would like any information regarding the upgrade please contact us or you may also visit the link below.
http://www.umiperformance.com/page.php?page=c5conv
Thank you!
Ryan
Thank you!
Ryan
I purchased UMI's C5 kit last month, and freakin love it!! My car will go into a complete nosedive by applying only moderate pressure. With light pressure applied, it's even easy to see the difference between the rotor sizes. They just grab so damn good!
I also love the fact that I'm not limited at all in choosing pad / rotor choices.
Aside from the fact that my aftermarket rim's backspacing wouldn't clear the calipers (Stock rims do), it's been the most worth-while addition to my TA. IMO, safety is numero uno. I mean, if you can't stop on a dime from 80, why cram thousands of dollars worth of go-fast-goodies in your car?
I have enjoyed this bolt-on mod. If you hunt around, do your research, you can do this without a ton of dough, and if you are handy with basic hand tools, you can do the installation yourself.
The only downside is adding a little unsrung weight from the bigger rotors but it is not too bad. You will need 17 inch wheels or bigger; right?
Can you just buy a set of OEM C5 brakes and rotors or do you need an adaption kit to go with it? Cus I am thinking about buying UMI's stuff, but if i went to go buy new pads, what year C5 do i put down for them?!
Also, can you use the C5 rear brakes too? Or can you only fit the fronts on there?
Also, Is there a difference between the C5 and C5 Z06 brakes?
If you need anymore help please ask. Thank you!
Ryan
Only LG's brackets allow the use of either f-body or C5 calipers and pads. That's the route I went.
https://ls1tech.com/forums/suspension-brakes/877090-c5-front-brakes-lg-brackets-noticeable-upgrade.html
I added the LG brackets and rotors only with my Hawk pads and it stops noticeably harder. It is said actual braking power is better with the f-body calipers, to the point that it shifts braking bias to the front a bit. In my mind, this is better for a street car, worse for an AutoX car. Besides, firmer dampers and a torque arm offset the extra nosedive on my car.
Both routes allow the use of OEM parts available at any dealer/parts store, which was one of my requirements.
This upgrade was well worth it, can't wait to redo all the pads and rotors again, along with some SS brake lines.
Complete UMI C5 brakeing kit here with brembo blanks, hawk HP-plus pads, Sams Strano's choice of brake lines that include even the TCS lines in the rear. Without a doubt this is the greatest upgrade one could do for our cars poor factor braking.
The cost and performance you get I just don't see much reason in getting anything else and the build quality of the brackets and included hardware are great. I love this mod.
For most people, you will never get the brakes hot enough to notice the difference (it's impossible on the street).
I almost did this upgrade but I really had a hard time justifying 300 dollars for brackets from LG. I really feel they are overpriced, well just LG in general. Especially when you can get the brackets where you need to cut the spindles for 150 from BMR
BCB001 Front - 1993-02 Camaro and Firebird. Adapter brackets only. $149.95
http://www.bmrfabrication.com/F-bodyBrakes.htm
but I really did not want to have to cut the spindles
why does the UMI brackets require C5 calipers?
No. UMI's kit REQUIRES the use of C5 calipers, PAB, and pads. It also requires cutting the spindles to mount the brackets. The upside is you get all new hardware, more durable calipers, better brake bias, and more + cheaper rotor and pad options.
