Rear Lowering springs
Re: Rear Lowering springs
www.ground-control.com
Buy the rear ride height adjusters and a set of springs....
Or, remove the rubber spacer above your rear spring and use a chunk of heater hose to cover teh top coil of the spring. That will lower the rear about 1/2 to 3/4 inch. If that is enough, problem solved....Good luck!
