Ride Height Adjuster or Air RIde Shocks
Just lowered my car with Eibach Pro springs- I am running
American racing 200s wheels with a bit of offset, when I go over a bridge joint or dip in the road the tires contact the inner edge of the rear fender, no tire damage but I can smell burnt rubber inside. Any suggestions on correcting this. Like the way the car looks and handles, but don't want to sacrifice any body parts.
Re: Ride Height Adjuster or Air RIde Shocks
www.ground-control.com
Buy the rear adjusters for ride height. $92.00 a pair as I remember.
In my opinion, DO NOT buy air shocks. Air bags will help some, but I think the adjusters will fix you right up. Good luck!
It is an easy install. I had to trim the bottom of one bracket to clear the panhard mount....3 minutes with a hacksaw. That was on a 3rd gen, and may not be a problem any longer. (I just had to notch the bottom of one side to clear the reinforcing bracket on the axle).
