M6 hookin up post
post you're 60' times, tire size, pressures ect.. suspension mods, motor mods, use of nitrous ect, what RPM you launch at, and how well the car hooks on the street as well as the track. thanks in advance guys!
F1 Supercar 295/35ZR18s @ 38psi
G2 coilovers (no help with traction there)
rod end LCAs
rod end panhard rod
BMR K-member
BMR upper A-arms (full rod end)
LG Lower A-arms (full rod end)
Edlebrock torque arm
SLP subframes (welded)
Wolfe 6 point cage (welded)
32mm front/ 21mm rear sway bars
with...
400wrhp/385rwtq
Spec Stage 3 clutch w/ aluminum flywheel
3.73 gears
I launch at 1500 - 2000RPM to TRY and avoid wheel spin.....
in otherwords....I DON"T hook in 1st....it just won't happen....
but then most races for me don't start below 55mph anyways....
There is a guy here in Phoenix that is about to start making them.....
Quick spin to clean off the tires
2.4 60' @ 30 PSI 1500 RPM Launch
2.2 60' @ 25 PSI 1500 RPM Launch
Mods in sig, stock suspension.
Didn't have a chance to launch any higher in RPM range or drop tire pressure more. Track closed
I slip the clutch out when I launch. The track dictates how much I actually slip it. If the track is good, I sorta just release the clutch slowly. Picture you are at a redlight next to a cop. Light turns green and you pull away, thats about the speed I release the clutch except that I have the throttle to the floor as I'm doing it.
If track prep is crappy, well I've slipped the clutch 3/4s of the way though 1st before releasing completely and it still spun. BTW, on a run like that the stock clutch gets very pissed. Usually have to let it cool for awhile after a run like that.
I do a decent burnout, not a long one but also longer than a clean-off spin. As for air pressure,,I had the best luck with around 28-30psi in the Firehawks.
