replace vacuum booster with hydro-booster?
Has anyone looked into replacing the factory vacuum booster with the mustang(or GM version) hydro-booster and run it off the factory power steering?
It would work better (more breaking force) and not put load on engines with high durration/tight LSA cams.
The power steering pumps are cheapy inefficent gear pumps this is one reason for their hot running. Being next to the engine doesn't help with heat either. So loading them with more work to do is not a good idae
Factory stuff as well as aftermarket products are a compromise between weight, efficentcy, cost and durability.
Do it and let us know what you break or if you still can.
