Clunk
Old Feb 18, 2008 | 10:23 PM
Red96TA's Avatar
Default Clunk
I dropped my 10 bolt out this weekend to do a little servicing, and maybe im just noticing it more because I didnt drive the car for a few days, but there seems to be a little bit of a "clunk" when I go over a bump or a rough spot in the road. Any ideas to what this could be? Everything got bolted back up like it was....
Old Feb 18, 2008 | 10:26 PM
waterbug1999's Avatar
Mine did that once, forgot to tighten the LCA bolt/nut to the rear end.
Old Feb 18, 2008 | 10:29 PM
Red96TA's Avatar
I tightened that down. This is buggin me bad...
Old Feb 18, 2008 | 10:33 PM
I had a shock go out and it made a clunk noise, but that was in the front. But, I suppose it could happen in the rear as well.
Old Feb 18, 2008 | 10:38 PM
Red96TA's Avatar
Never thought of that...That would be a major coincidence though that it would go out just as I put the rear back in..
Old Feb 18, 2008 | 10:41 PM
Red98maro's Avatar
check ur rear sway bar, mine did that, and my sway bar bushings were completly gone on pass side
Old Feb 18, 2008 | 10:42 PM
Jakester136's Avatar
maybe the shock went out becuase when you dropped the rearend it was extended out all the way for a while and lost some of its charge-after all its used to having pressure on it. Maybe not just a thought
Old Feb 18, 2008 | 10:44 PM
Its hard to say.. What did you have "serviced"?
Old Feb 18, 2008 | 10:53 PM
Red96TA's Avatar
it had a whine so i took it apart to see what was up...turned out my pinion bearing was going bad...replaced all the bearings...axles, pinion, and wheel bearings, put new seals in the pinion and wheel bearings, bolted the rear back up, and it has a clunk now when i hit bumps
Red96TA's Avatar
the shock wasnt ever extended...we unbolted those before lowering the rear with a jack
Old Feb 18, 2008 | 10:55 PM
Well I guess that rules out my Hypothesis..lol
Good luck man!
Old Feb 18, 2008 | 11:07 PM
Well, you had to have unbolted the shocks either from the top or the bottom, in either case they are going to extend all the way out.
Old Feb 18, 2008 | 11:20 PM
Red96TA's Avatar
I unbolted them from the bottom and they sucked up in the shock itself....
Old Feb 18, 2008 | 11:33 PM
How old are they?
Old Feb 19, 2008 | 09:01 PM
SLV_WS6's Avatar
My car is doing the same thing, when you hit a bump, go over a speed bump there is a clunking noise that comes from the rear I think, its driving me nuts, my husband is going to install my shocks, struts and new springs, and some other misc suspension parts, is there any other stuff that might be causing the noise. I dont want to ask him because it already frustrates the hell out of him. Hopefully once we install everything it will go away. Other than the clunking there is no vibration.
