KYB AGX Guys, question about stiffness.
What stiffness do you guys leave your shocks on for daily driving? I had a Prelude with Tein Super Streets and I usually just left them on the highest stiffness because I didn't mind it. Do any of you drive around in your F-Body like that?
Also, what do you set them to when running at the track?
how are these shocks with strano springs? I know koni's are better but i want springs and shocks and i can't spend that kind of money. Do the KYB's perform well on those shocks?
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Since you can adjust the KYB AGX it is all up to you. Hope you have stock springs cause that is all I can vouch for.
I love these KYB's. I have mine set on 5 and the turning is sharp. I can't wait to test out the other settings.
yea i got the AGXs, when i first put them in i had them on 7, and i went into a pretty choppy turn that i have to take everyday to work, and the rear almost hopped into the guard rail, so the next day i had to slow down alot to make the turn safely. so i turned the rears down to 3 and now i can rip through the turn no problem. so keep in mind what kinda streets u drive on. my 2 cents
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
So i got mine in and tried a few things:
5/5 rear was too stiff
6/4 front bounced too much over crappy roads
5/4 and that has worked out really well for DD, and a lil jont through a mountain pass.
I can't wait to drop the F sway and try 1/6 for launches.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Stock springs btw. Ditched the pro-kit to go with the stranos later on.
