anyone know where to find individual rear lowering springs?
as the title states. i have looked everywhere and cant find squat! the closest thing i've found is ground control and there adjustable 350$ ride height kit, but im talking a little cheaper than that. anyone?
Vince,
You can buy "loose" Eibach springs from www.truechoice.com. YOu will want a 5 inch diameter with a pigtail (as I remember) and I think you'll want that to be 9 inches long. This is based on the fact that ground control sells 9 inch springs for their adjustable kit and the last one I used was 1/4 inch from the bottom and the car sat fine (with no rubber isolator), so, if you use the isloator to make up the difference, you may get lucky and have it all work out. Otherwise, you'll need 11 inch springs and have to cut them and then torch the end to bend it flat (so it sits on the body (I can't believe I just said to torch a spring....that is "unnatural" to me....ewww). I can't promise what your rewults will be, but that is the best starting info I can give you. Good luck!
