help decide which rear springs
Im just looking for a 1 -1.5 drop max for the rear. Which springs should i go with that will still have a stock/decent ride with the stock shocks that only have 30k miles on them? Does anyone have anything there looking to sell maybe a shock /spring combo or just the springs?
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
On a side note we are running a killer SALE check it out here-
http://www.bmrfabrication.com/taxrefundsale.htm
We offer a rear lowering spring that sounds like it would fit the bill perfectly. The rear only spring part # is SP003 and will run $125.95 here is a link to the page http://www.bmrfabrication.com/F-bodySuspension.htm This rear spring is a 1.25" progressive lowering spring so ride quality is not compromised when lowering the vehicle. If you have any other questions regading our products please feel free to ask....
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
But how do your progressive rate lowering springs behave with stock shocks? I doubt the stock shocks have the proper damping capabilities - they don't even work well with the stock springs...
I personally would never buy springs first (too use with stock shocks) - I would at least buy the shocks first - then the springs - optimum would be to buy spring/shock package that work together.
With progressive rate lowering springs and stock shocks you would be worse off as far as handling goes.
Kinda like buying a killer set of heads without the appropriate cam to go with them to realize the full potential of the new heads -or- visa versa
