Other parts needed for install?
here in the next week, i plan on putting qa1 coilovers up front and bmr springs with single adjustable qa1s out back. are there any other accesories i will need to make these parts work? i've heard about rear qa1s needing a special bracket here or a cup for the springs there, so can someone please straighten me out on this???
also, what are the advantages of running a v6 rear spring? i've heard of some guys doing this also...
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
http://www.bmrfabrication.com/F-bodySuspension.htm
If you are going to use the QA1 springs then the adapter cup is not needed. The rear QA1's are a direct replacement so nothing is needed there. I don't recommend using the V6 rear springs they are too low of a spring rate for drag racing the stock V8 springs are a much better choice.
