Torque arms.
12 bolt moser
6 speed car
Stainless works LT headers/catted y-pipe
SLP dual/dual
I've read that the tunnel mounted is the way to go, as well as grab a driveshaft loop. But beyond that I don't know what to choose as far as which works for what rearend, and will fit my exhaust? Any help is much appreciated.
Our tunnel mounted torque arm will fit all rear ends and will clear your exhaust. Below I pasted a link to this time, please take a look and let me know if you have any questions.
www.umiperformance.com/2203
If you are unsure whether this set-up is for you or not please PM me the details on how you drive the car and what your plans for it are. Along with a list of your current suspension mods including shocks, springs and what type of rear end.
You may also call our tech support at 814-857-5400
Thank you!
Ryan
12 bolt moser
6 speed car
SLP dual/dual
Thanks
The problem right now is with the Vogtland Springs, which I believe to be completely horrible, the exhaust at its lowest it point is maybe 3 inches off the ground.. I am looking into several different routes at the moment, because it has no suspension travel and is just a horrible, harsh, worthless ride. Decent stance, but that's it. Im just hoping the the KYB's aren't getting to destroyed. I am probably going with the UMI tunnel mounted adjustable arm. The Best V8 Stories One Small Block at Time
