Panhard bar?
a nice solid piece of metal vs a stamped sheet of metal. Plus, the adjustable bar does help re-center the wheels after lowering.
The adjustable version is the only one that will allow you to make the side to side adjustments to correct the rear alignment. The non adjustable panhard bar is a fixed length so if the rear alignment is off you CANNOT make a correction.
Like BMR said you can get away without one but it wont be perfect, I would have done it anyway just to get rid of that stamped steel stuff.
