WS6 Sway bar and DIY PHR ??
Hi,
I thought I read somewhere the front sway bar on a 2001 WS6 is 32mm is that right? Would changing to polyurethane bushings and end links make much difference to bodyroll?
Also where did I read about building my own PHR and does it really make much difference?
Thanks in advance for your advise.
Thank you for confirming the 32mm bar for me UMI Performance.
I just refound the guide to the DIY PHR.
So, would changing to polyurethane bushings and end links make much difference on a stock 32mm bar?
If you are looking to improve handling shocks are the first thing you should look at with these cars. With quality ones its a night and day difference in handling and ride quality.
