warped rotars help.
Also, this is not a problem specific to the F-bodies. I had similar problems on my '95 ZR2 and my '95 Grand Am. In both cases I installed ACDelco Durastop rotors and the problem was cured. On the other hand I had almost 90,000 miles on my '88 Oldsmobile rotors and I currenly have 35,000 miles on the original rotors on my '01 ZR2 with no problems whatsoever
I guess its just luck of the draw... Look for Brembo OEM rotors, $61 each. I just replaced a set that I ran with very destructive race pads. I had removed 212 thousandths of material off the rotors (nearly 1/4 inch of wear) and no warp. They were 4mm under spec when I removed them. It is not the rotors fault, I am running full race compound pads on my car (daily).
