Alignment help please
Old Jul 31, 2003 | 01:35 PM
Sniper33's Avatar
Default Alignment help please
I'm going to have DMS springs, revalved Bilsteins and 18x9.5 Z06 wheels installed. Do these sound like correct alignment specs when I get it done afterwards:
(Caster) 4*
(Camber) -.7* to -.1*
(Toe) 0
Or do I have them mixed up??
Thanks, Joe
Old Jul 31, 2003 | 04:31 PM
SSixspeed's Avatar
Default Re: Alignment help please
You have the numbers in the right places. I think factory caster is closer to 5.3... I run +4.5 caster with -1.8 camber 0 toe
Old Jul 31, 2003 | 10:56 PM
trackbird's Avatar
I run +4.5 castor as well....you are headed in the right direction....
Old Aug 1, 2003 | 12:27 PM
Sniper33's Avatar
Thanks guys!! But the camber I'm looking at is fine right??
Old Aug 1, 2003 | 02:57 PM
trackbird's Avatar
FOr street use (and some autocross), the toe and camber are great....
Old Aug 1, 2003 | 03:46 PM
Sniper33's Avatar
Maybe this would've helped too. The car is a daily driver, sees the strip occasionally, and is never autox.
Old Aug 1, 2003 | 04:31 PM
SSixspeed's Avatar
For straight line and daily driving I would stick with -.5, just to get better turning on the street. But you may want to ask in the drag race section...
Old Aug 1, 2003 | 10:56 PM
trackbird's Avatar
Based on your last statement...for street I'd look at a camber setting of -.5 to -.7 (if you are not as worried about handling). That will help you get even tire wear and it will still handle just fine.
