Ever install a C6 IRS on a 02 Camaro?
Performing some research on various suspension setups for unrestricted road racing. Looking to see if anyone has installed a c6 irs on a 02 f-body.
I know I can keep the stock set-up and get some decent handling, but the research seems to indicate IRS yields better results. Forgot to mention, my wife really likes the camaro so upgrading to a vette is out of the question…
Does this sound right or did I hit my head too hard while I was under the car yesterday? LOL
Any help would be greatly appreciated!
Thanks
Thanks
Here is a link to someone who put a c4 irs under an fbody. https://ls1tech.com/forums/showthrea...ght=f-body+IRS I believe a c5 and c6 setup would be out of the question without some serious fab work due to the transmission sitting in the rear of the car rather than bolted to the engine. However where there is a will theres a way and i hope you have the cash to pay, because it would be really expensive and time consuming working all the bugs out imo.
A used Z06 would be cheaper...
You can start with this and go from there:
http://www.stranoparts.com/partdetai...ID=0&ModelID=7
Ill tell this though, you won't be disappointed with the handling after this kit...
Thanks - I totally agree with the corvette angle; but I am a married man and my wife and i have had huge fights over swapping the 4th gen for a vette (it is an 02 convert and can seat her and my daughter, which is the basis for her arguement). So getting the corvette is out of the question for now. But the good news is she likes it when i modify the car!
Great recommendation for Sam's products - I though they worked well but did not know it was capable making that much of a difference.
Seems like the live axle may not be such an anchor afterall. Thanks again!
Nah its really not as bad as you think. I have his HP4 package and i havnt been able to find the outer limit yet. I did get it to slide once but i think that was due to the crappy tires i have on it rather than hitting the limit of the suspension. In fact i would almost say that you could probably go toe to toe with a stock c5. But being that i have never driven one kinda makes that a bold statement.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
You need to get control of that wife of yours!
haha jk jk...
You could also consider a CTS-V, those are plain out sick and handle on rails!
You just gotta take into consideration all the engineering that has gone into the C6 Z06 compared to our cars. Aerodynamics, chassis layout, lightweight wishbone suspension, etc etc. It would take a lot to get the same feel and control you get from that kind of layout.
It's interesting that the IRS endeavour has been explored many times with the 4th Gen F-body, but most of the solutions are costly and still don't address the real problems with the 4th Gen handling and comfort, which brings this statement right back to the most effective improvement that these cars need, good dampers.
Good dampers are the place to start with if it's concerning handling in this car. The next step would be swaybars, then maybe springs if you need so. Like the previous posters have mentioned, these areas are great places to start. I don't remember what LCA's you have in the rear, but if you plan to keep the stock ones for the moment, then you'll need some new "solid rubber" bushings for them. Also, if you opt to lower the car, you'll need to consider a new PHB with at least one rod-end in it.
If you plan to get into some sort of unlimited class, then you might want to take a peek at this website: www.frrax.com. There's also been some discussion about extensive modifications on there (many of these for the serious competitor in mind).
Overall your going to have a pretty hard time to match the handling of a c5, c6, or even a c4 no matter what you do. Don't sweat it though. The fbody in stock form has a lot of potential for improvement in suspension as most know. But on an autox course, the vette is just at a different level than an fbody. The vette is SS competitive which is basically the highest of stock classes while the fbody is good in FS. Quite a big handicap difference applies.
+ million to all of the above suggestions, and I'll add;
Get a Torsen T2R diff (IF you still can??) or an Auburn 'Racer's Diff'.
With the above suspension recommendations, sticky tires, good brakes you'll be that much closer to a Vette in the handling dept. (well a stock C5 at least).
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Stock for stock that would leave an fbody in the dust (although thats not really saying much...) And I'd have to drive one again (drove it before I had any suspension mods) but I think it would be a good race between a Koni/strano swaybars fbody and a stock CTS-V in the corners. Those things have ridiculously good balance and composure.
My buddies dad has a '92 (im pretty sure its a base model, not a Z51) and my car currently out handles it, thats for sure. You can feel that the C4 is lighter, but the suspension actually feels kinda sloppy, and "relaxed" in comparison to my setup. I'm sure a Z51 model would be a different story though...
Im not trying calling you out on either of these quotes, so please don't take offense but have you driven a C4?
Back on topic, though, I really don't see the point of swapping IRS into an f-body. The stock rear suspension isn't bad, and it can be made to work better.
*friends dad. Like I said, its stock, non-Z51 suspension.
What is done to your fbody?
My C4 handles significantly better than my LS1 f-body, and I'm still running OE springs (Z51 springs). The C4 has better front and rear geometry, better weight distribution, and lower overall weight. C4's have won numerous SS (when they were in SS) and AS (current class) national championships. A C4 IS faster around an AX course (in fact, AS is faster than ESP by just a bit, ie: a stock C4 is faster than an ESP prepped f-body). http://www.scca-chicago.com/solo/indexes/rtp2008.html
It's an FS car, so Strano 35mm front bar and Konis, stock otherwise.
An ESP setup would handle better than the current setup, but I think we all knew that. My point was this: even in ESP trim, an AS C4 is STILL faster around an AX course (if just barely). I'm not saying a setup f-body can't handle, but I DO say that a C4 will handle better.
