braking problems after mods
Old May 19, 2008 | 07:02 PM
PeewterSS4.8's Avatar
Default braking problems after mods
Hey guys my 2000 camaro ss A4 recently got installed
livenoise stage 2.5 LS6 heads
MS4 cam
Fast 90/90
ASP pulley
Pacesetter race LT headers with ory andSLP loudmouth 2
HP tuned
and doesn't brake as good as it did before i got all those mods installed what should going bad or went bad???
Old May 19, 2008 | 09:57 PM
Mojave's Avatar
What do you mean doesn't brake as good?
Do you have any vacuum for the booster to actually work?
Old May 20, 2008 | 12:13 AM
proelky's Avatar
Check all of your vacuum lines....
Old May 20, 2008 | 07:37 PM
Befor i got all of the mods in there it braked normal but now it doesnt. I need to check the vacum lines.
Old May 20, 2008 | 10:52 PM
Mojave's Avatar
What isn't normal? Pedal effort? Noise? Vibration? Sponginess?
Old May 21, 2008 | 01:06 AM
Pedal effort.
Old May 21, 2008 | 11:42 AM
Sam Strano's Avatar
LS1TECH Sponsor
You are losing power brakes. Some to all....
You could have a leak, or the cam might be too big (I'm not really into cams) to provide good vacuum to the booster.
If you had no issue before, but do now, it's related to the can swap. Either a line that isn't sealing right, is off, or it's the cam itself. It's easy to check for a leak with a bottle of propane.... run it around and if there is a leak the propane will get sucked in and the idle will rise.
__________________
Old May 21, 2008 | 02:59 PM
xBROKEx's Avatar
did you tune the car after the mods? if not your prolly not getting enough vaccum
