panhard relocation
Old Jun 2, 2008 | 11:16 AM
dutinsss's Avatar
Default panhard relocation
would the panhard bar relocation kit make it any easier to run 2.5'' true duals over both sides of the axle? mine are run under the axle right now but i want to get it cut off before the axle and have new pipe run over it on both sides because of clearance issues. just wondering if this kit would help it clear on the DS as well. thanks
Old Jun 2, 2008 | 11:56 AM
cookba's Avatar
what you need is a UMI panhard bard relocation kit, item #2024.
Old Jun 2, 2008 | 12:22 PM
dutinsss's Avatar
yea, thats what i'm talking about haha. i know it helps pipes clear on the PS, but will it help any no the DS?
Old Jun 2, 2008 | 12:31 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Here's another option for you. Our panhard relocation kit PHR004K gives you enough room to run up to a 3" true dual exhaust over the rear axle. If you have any questions please give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jun 2, 2008 | 12:40 PM
dutinsss's Avatar
does this kit increase clearance on the DS and PS, or only the PS?
Old Jun 2, 2008 | 02:41 PM
BMR Tech's Avatar
It creates more room over the passenger side of the axle not the driver side.
Old Jun 2, 2008 | 10:38 PM
dutinsss's Avatar
ok, i dont need it then because i'm going to have one 2.5'' pipe over each side of the axle. i was just wondering if it would help in fitting the DS pipe over the axle because i know it will clear on the PS. thanks.
Old Oct 9, 2008 | 09:23 PM
James Montigny's Avatar
Does the upper brace being that close to the PHB cause issues when going over bumps?
I installed mine last week, looks like the picture above.
Old Oct 9, 2008 | 09:39 PM
02Z28LS1's Avatar
is there any particular reason you want one pipe to go over each side of the axle?
is it just a preference, or are you trying to avoid as many bends as possible, or what?
Old Nov 19, 2008 | 09:47 AM
BMR Tech's Avatar
Not that we have ever experienced.
Old Nov 19, 2008 | 11:57 AM
97LT1Kid's Avatar
With the relocation kit (even without for 2.5") you can run both pipes over the PS. This also allows the pipes to be tucked up nicely in the tunnel for optimum clearance.
