Need Help! No Traction!!
Is this solely a tire issue? I am currently running on some 315 Nitto 555R's with a tire pressure of about 20psi's. I have some UMI Subframe Connectors, UMI Adj. Panhard Bar, Strano Springs, and Koni Shocks.
I have the rears on full soft but it feels too soft. It feels like the rears don't take the bumps well and I feel no rebound.
Whatcha guys think? I'm a manual at stock power levels too.
20 psi, is´t that way low? I´m running 30 psi in the rear. Can it be so that if you run to low tire pressure the dampers will not react or work as they should. Due to the softness the tire will work as your suspension, the springs and dampers are not doing their job. Play with the tire pressure and let´s see what happens.
Its been said by others, "Girls Squat.. Race cars don't!"
I don't think it's a saggy spring. These are 1 year-old Stranos.
I'll play with the Koni settings. I don't wanna get flamed for this but, . . . . I actually don't have the Koni's set up in the front yet. I've been dealing with some family health issues and haven't had time to work on the car and I know how Sam emphasizes suspension parts working together, I jus' didn't know front shocks affect planting of the rear.
One other comment, I didn't quite mean launching launching, like from a dig, jus' whenever I floor it on the streets.
Thanx!
Is this on the track or the street that you aren't getting traction? The street condition, temperature, etc can change your traction. 555r's I wouldn't really consider a drag radial. Hell I use them for autox, so they have a decent sidewall. Not competitive by any means in autox! lol but they work and are doable.
You also didn't mention relcation brackets. The LCA angle when the car is lowered hurts traction more than when you were at stock height. Relo brackets can help you put the power down when the LCA's are put in lower holes. Though... if you plan to any autox or road racing, I'd highly recommend against getting relo brackets.
I'm holding off on the LCA's themselves because other internet sources are stating that LCA's flexing or binding are necessary. I wanna see how well it works first.Never been to the track, it's jus' street driving. When I floor it, it feels as if my car is hovering over the ground jus' partly grazing the road.
