what rear brakes clear 15" rims
what brakes will clear 15 in weld prostars? I'm currently putting my 9in together and want to figure out what brakes i should use.. or just keep the stock ones.
I have an LT1 with Holeshots...had to grind quite a bit off...possibility someone before me put diff calipers on the car?
I need to put new brake pads on the car and will have to grind some more. Will change to these if thats the case. Is there a specific year LT1 caliper thats best for this?
Lt1 brakes will still require grinding to fit prostars and most 15" rims. Some 15's will just barley clear LT1 brakes with no grinding like Summit/jegs stars, centerline convo pros, and Billet specialties streetlites. for prostars and no grinding the only choice is drag brakes.
