SwayBar End Links....
I changing out my rear swaybar endlinks...the long bolt of the new endlinks, is approx one inch shorter than the old endlink bolt....is that the way it is? or should i just use the old bolt??
Swaybar endlinks should be whatever length is required to position your swaybar ends approximately parallel to the control arm when the vehicle is at ride height. Generally this relationship will be altered if you lower the car or something. Energy Suspension makes endlinks in various lengths and you can get them through Jegs or Summit. Here's a good link for illustration: http://www.energysuspension.com/endl.html
