"ASR", "ABS INOP", "BRAKE" lights all on!!!
I've seem to have hit the warning light trifecta with "ASR", "ABS INOP", "BRAKE" all lit up at the same time. The brakes seem to work fine (the right rear squeeks like hell, however). This happens after about 15 minutes of driving but does not effect braking at all. Any ideas??
your gonna have to hook up to a scanner that can read codes from your brake module. since the lights are on, your ABS and traction control will be disabled until the problem is fixed...maybe a wheel speed sensor fault....
