Car feels loose on the street.
Old 08-31-2003 | 05:50 PM
maddboost's Avatar
Default Car feels loose on the street.
I recently noticed that the steering in my car feels very loose. And it feels like im needing to put more effort into keeping it on the road when making turns on the highway. What could this be? Shocks, steering rack, something else? My car has 75,000 miles on it and has all the original suspension beside new LCAs with relocation brackets. Also as a side note but I dont believe it has anything to do with the suspension, I recently had a stall put in and now my trans is showing signs of slipping.
Old 08-31-2003 | 08:29 PM
wrencher's Avatar
wrencher
Default Re: Car feels loose on the street.
More effort to keep it on the road, do you mean it has memory steer, or is it following the cracks in the road?
Have you checked tire pressures? Front end componets?
Does the car bounce excessively over bumps?
As for the trans did you check the fluid is it full? Burnt?
Old 08-31-2003 | 10:19 PM
maddboost's Avatar
I check my tire pressure 3 times a week. It seems to pull with the cracks in the road more than before. And it feels to bounce more over bumps its a loose feeling not a rough feeling. Ill have to check the trans fluid in the morning but the trans is on its way out regardless but that wouldnt cause the "floating" feeling I seem to have, would it?
Old 09-03-2003 | 10:58 PM
maddboost's Avatar
Anybody got any ideas?
Old 09-03-2003 | 11:28 PM
wrencher's Avatar
wrencher
Depending on the milage on the car the struts/shocks are prolly worn.
Have you had the car aligned lately?
That will help from following every crack in the road.
Dont overlook the front end componets.
Ball joints, tie-rods, rack mounts & front wheel bearings all have a major affect on the way the car "tracks".
By loose feeling is that play in the steering wheel?
Old 09-04-2003 | 12:31 AM
maddboost's Avatar
I wouldnt say the steering wheel is loose but the car just turns looser.
Old 09-04-2003 | 08:24 PM
joecar's Avatar
"It seems to pull with the cracks in the road more than before."
This is a symptom of worn A-arm bushings, ball joints, and tie-rod ends.
"And it feels to bounce more over bumps its a loose feeling not a rough feeling."
This is a symptom of worn shocks.
"trans is on its way out regardless but that wouldnt cause the "floating" feeling I seem to have, would it?"
The trans would not cause that.
Old 09-06-2003 | 06:10 PM
hawaiiboysz's Avatar
Try getting new shocks and replace your most likely worn out bushings around the car.
Quick Reply: Car feels loose on the street.
