who's f-body is LOW?
Like the title says... looking for some pics and info on people who have their f-bodies LOW! Im not talking a simple eibach pro-kit or regular 1.5" kits... Looking for someone with coilovers or something that runs around low. Post up pics and info ! Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Are you looking to drive this on the street or just use it for shows? 2" is really low for street use and any lower than that is only going to make it nearly impossible. I use to have a pic of a car lowered 2.5" somewhere that I'll try to find for you, it should make things rather clear as to it not being streetable.
I had a pro-kitted car and there was no clearance issues. I'm looking for a slammed car that is set-up to handle like a champ. Vettes run around lowered and are MUCH lower than our cars. Im sure some people out there with coil-overs are slammed... post up!
__________________
Kleeborp the Moderator™
A slammed car that is set up to handle like a champ won't really work with these cars...you'll basically end up with too little shock travel to properly damp the springs. You'd probably be looking for something like airbags...beyond that, a Prokit is as low as I'd go with one of these.
That and you can't compare an f-body to a Vette...those are just two entirely different animals with how everything is set up.
"slammed car" and "handles like a champ" usually do not go in the same sentence for a street car.
If you want a car that "handles like a champ" talk to Sam Strano, I think multiple SCCA wins speak for themselves... With his setup you won't believe you are driving the same car, it lives up to the hype.
Probably the good ole Eibach Prokit rear spring sag.
To get a F-body to handle you do not have to slam it to the ground.
Take some time a read this article
http://www.gmhightechperformance.com...aro/index.html
not to bead a dead horse, but if you really want to handle well, get koni SA and strano springs. that will get it as low as you could want, and nothing will handle better. ive gotten plenty of compliments on my cars stance. 'slamming' an f-body just looks trashy and stupid. the biggest clearance issue will be your exhaust. if its stock or just cat-back, you should be alright. headers and catted-Y will be a problem, depending on how tucked up you can get it.
I think you already asked about my ghetto-awesome suspension didn't you? I wouldn't exactly say it "handles like a champ."
ok guys, i dont want this to get into a shitfest here. I am not looking for a ghetto who ride on airbags for shows. I am simply asking about lowered cars. I figured on coil overs you could go pretty low and still handle great with the low CG.
97RedTA, your suspension looks awesome! How is the ride around town, does it ride like **** or not really? Do you bottom out a lot of stuff? I think you said its sportlines with a coil cut up front?
__________________
PM "00 Trans Ram" and ask what is average ride height is.
https://ls1tech.com/forums/member.php?u=20116
As you can see here, he has a road racer with adjustable coils:
https://ls1tech.com/forums/road-racing/968246-anyone-got-c-prepared-4th-gen-f-body.html
His car certainly doesn't look slammed.
Actually, I think it was more like 2 cut in front and a half in back. It's really not much worse than just regular sportlines- the coils on the end were all flat already- So I guess it didn't really change anything about the springs except made them shorter. I'm sure some good shocks would help a ton, too. Of course you have to be careful what you drive over, but with a little finesse, I can get it over most speed bumps without even touching.
Autofab Coil-Over kit with QA1 Drag shocks all around. The receipt from the previous owners said "QA1-Autofab Kit 300" So maybe thats 300 spring all around? I'm ripping them out and going back to shocks and springs, then i'm selling the QA1's and coil over kit.
Pics, (car wasnt on a fully flat surface)
on the street:
on the street:
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Mine is as low as I can reasonably get away with...... [mine sat low in stock form for some unknown reason, as you can see with stock spring/hose in rear W/Bilstein]] [Car was new...18 miles on it or something..gotta look it up for sure]
I have the BMR springs, the fronts have a coil cut and in the rear I have the isolator out and the hose mod done. Everyone says my car is stupid low. I'm getting coilovers in the next month or so, so I can lower the front just a bit more and the rears I'm thinking about getting the sportlines. I love the look of a slammed car. Granted I have a good amount of trouble now getting around, but hopefully soon I can get a custom Y-pipe made because that's my mail source of trouble...as you can see...
BTW LT14mula...your car looks sick man.
