Pro kit people...is this right?? (bump stop question)
remove the bumpstop spacers. for sure, you're riding the bumpstops. you're not even feeling the pro-kit spring rate back there.
if you're getting sound during articulation of the rear suspension, check to make sure your rear springs are seated correctly as there's not much clearance, they could be hitting the body. check the springs (actually, check everywhere to find out what it is) for wear marks.
