solution to 9 inch + sway bar fittment
so after trying the washer idea and not totally being satisfied with the out come I decided to go a different route...A bunch of washers at the end of the 3 inch muffler clamp didnt totally work very well so instead I went to Truevalue and picked up some 3 inch u bolt plates and now the bushing has a flat surface to rest on and the sway bar isnt rubbing against the rear end...
+ I picked up energy suspension endlinks from kragen for the rear but after calling them turns out the company doesnt make any for the rear of a camaro just the fronts(9.8118r) so I think I might keep them and reuse the old sleeve if it fits.
There are mounts that you can weld on that will allow you to bolt your sway bar right up.
http://www.bmrfabrication.com/misc/mount-kit.jpg
http://www.bmrfabrication.com/F-bodySuspension.htm
SWAYBAR MOUNT KIT for aftermarket rear ends
SMK001 Kit for 19mm swaybars and 2.5" - 2.75" axle tubes $72.95
SMK002 Kit for 22mm swaybars and 2.5" - 2.75" axle tubes $72.95
SMK003 Kit for 19mm swaybars and 3" - 3.25" axle tubes
$72.95
SMK004 Kit for 22mm swaybars and 3" - 3.25" axle tubes $72.95
SMK005 2.5"-2.75" brackets and hardware only, no bushings $34.95
SMK006 3" - 3.25" brackets and hardware only, no bushings $34.95
Have an aftermarket rearend but no way to mount your swaybar? This kit is the solution. Kit contains laser cut, weld-on bushing mounts, polyurethane mounting bushings and endlinks, and all necesarry mounting hardware. Fits all popular Ford 9" and 12 bolt F-Body rear end housings.
$72.95
