Fs: 408 stroker-built 6 speed and ws6 roller
Ill start out with the 408 this is a 11.5 to1 compression with the heads that are on it now. Selling this cause im getting rid of everything. This motor was built by erick at hke have all the build reciepts. Motor comes with heads and cam on it. Motor has around 500 miles on it. $3000obo
6 speed transmission is built by 6 speed inc back in the day this is a stage 3 build with the viper input out put shaft. Will also come with spec stage 3+ clutch and an aluminun flywheel. $1500obo
2000 pontiac transam ws6 roller
this car is almost fully built it ahds the drag setup with qa1's upper and lower control arms subframe connectors adjustable tourqe arm 373 gears shift light t-tops just needs the front bumper put on and painted also has big and skinney welds on the car.have title in hand $3000
just done dealing with this car hopefully somone will have fun with it just dont have time and it just sits there.
motor trans and car $6500
will post pics in alittle bit ITS THE CAR IN MY SIG.
The motor was built for spray the heads are 317 ported and polished milled .010 for compression all internals are forged have build reciepts. No dyno numbers hasnt been on the dyno just had a base tune in it has 500 miles on the motor the tranny has 5000 miles on it.
