TFS 245's, Solid Roller Cam, Kooks, Rockers, Super Vic
TFS 245's 6-bolt. Set up for solid roller
-Machined spring pockets for 1.55 diameter springs
-Brand new never ran Manley 22440 springs. Max .720 lift
-Standard Ferrera stainless valves
-Comp 1732 10 degree spring retainers
-Comp 4781 spring locators
-Comp 632 8mm 10 degree locks
-Never been milled, standard 70cc chambers
-Have approx 2000 miles on them. 0 miles since repair work, valve job, and new springs.
Motor and heads were originally setup by AES. Spring pockets where cut into the intake port. I ran the heads just like that for for awhile with no problems, no oil consumption, smoking etc. I just had Frankenstein racing heads repair the heads, he welded both the intake port side and the spring pocket side. And then re-cut the spring pockets. He also did a valve job on the heads. Heads are fresh and ready to go. Springs were setup by Lenmar. I have over $1000 in springs and repair work in these heads since I last ran them. $2000 firm. With a spring change they could be used on a hydraulic setup, standard length valves. Only selling to go to LS7 setup.
Edelbrock Super Victor intake. Will come with rails and fittings and throttle body. NO INJECTORS!!! Intake has some slight port work by AES, and has been port matched to the TFS 245's above. Fast 4150 Tb. Comes with TPS and IAC. Also Jegs throttle cable support, not shown in picture. No problems with anything. Asking $800
Lunati shaft adjustable rockers. 1.7 ratio. Two sets / Four rockers are brand new due to pushrod failure. No problems, nice set of rockers. Asking $350
Kooks 1 7/8th stainless headers. Ceramic coated. In great shape, and only used for about 2000 miles. Comes with kooks y-pipe that is also ceramic coated. Y-pipe goes into a single 4 inch dynomax bullet. Nice setup. No major dings or scratches. But has normal install and removal marks. Comes with almost new oxygen sensors and extensions. Asking $900 for both. Will not separate.
98 TA gray leather seats. Front and back. In good shape. Car had 70k miles. Driver seat is starting to rip, see pics. Asking $300.
Wilson manifolds 105mm intake elbow. Dominator flange. Painted black. Has a throttle cable for a lokar cable welded on it. $150
Comp solid roller cam. Spec'd by AES for out of the box TFS 245's. 268/272 .646/.646 110. Has approx 2000 miles on it. $250. No pics right now, as it's still in the short block. Still have cam card. Can get pics if needed.
Will update later with more parts. Have 2 solid roller cams, 8.325 3/8th pushrods, brand new Manton solid roller lifters, Nasty fabricated valve covers, etc...
