Texas Classifieds Sell your items and vehicles here in Texas
need passenger side tail light
Old Mar 9, 2012 | 11:11 AM
mr_montellano's Avatar
Default need passenger side tail light
For my 2000 trans am
Need asap im located south of houston but can drive a reasonable way for one...
Old Mar 10, 2012 | 11:13 AM
Ballerado's Avatar
Do you need one because yours is dark, or you just need a replacement. I have one, but it is dark. Im down by kemah.
Old Mar 10, 2012 | 03:30 PM
Need one cause its dark. I got pulled over cause one was darker then the other...
Old Mar 11, 2012 | 11:59 PM
Bump to the toppers
Old Mar 12, 2012 | 08:57 AM
FireHawk178's Avatar
Bump and question. Is the "darkness" a common issue? Mine is doing the same on the same side. First thought was bulb(s), nope, second was fungus because I've had water get inside which doesn't seem to be the case either.
Old Mar 12, 2012 | 09:19 AM
Donohue96M6Z28's Avatar
Yup, water seeps in and ruins the reflectiveness of the light.
Old Mar 12, 2012 | 09:22 AM
mike171562's Avatar
same problem here, never got pulled over cause of it. There is a write up on another forum on how to fix it which involves using a heat gun to take it apart and re-spray the back.
Old Mar 13, 2012 | 04:32 PM
Bump... need one asap
Old Mar 13, 2012 | 04:34 PM
DopeFedZ's Avatar
Let me check i used to have sitting somewhere at the house. Ill post up if i find it.
