Delete add
Ok I know I've been getting this ready to run but...Things have changed so I'm selling this... I'm not hard up for money so don't think I'm going to give it away.
94 CAMARO Z28 RACE CAR
THIS CAR HAS ABOUT 12K IN PARTS. EVERYTHING IS NEW.
THE CAR HAS BEEN FULLY PAINTED UNDERNEATH
ALL THE SUSPENSION IS CHROMOLY AND CAGE.
$7,000 OBO
HERE IS A LIST OF WHATS ON THE CAR.
MIDWEST FAB 9" WITH 4.11 GEARS, 5/8 STUDS, NODULAR CASE, AND ADJUSTABLE LOWER CONTROL ARMS.
RACECRAFT FULL FRONT END SUSPENSION WITH SPINDLE MOUNT WHEELS, ADJUSTABLE UPPER AND LOWER CONTROL ARMS.
AEROSPACE BRAKES FRONT AND BACK (FRONT BRAKES ARE TWO PISTON)
RACECRAFT STEERING TUBULAR COLUMN WITH QUICK DISCONNECT STEERING WHEEL
KIRKEY SEAT WITH REAR MOUNT
WOLFE FULL CHROMOLY CAGE
STRANGE FRONT AND BACK ADJUSTABLE STOCKS (COIL OVERS IN REAR)
AMERICAN RACING WHEELS
HAVE NEW FRONT END AND DRIVER SIDE FENDER
B&M SHIFTER FOR POWERGLIDE
BMR CROSSMEMBER
MANUAL RACK AND PINION
RACECRAFT UPPER A-ARM MOUNTS
BMR WELDED SUBFRAME CONNECTORS
RACECRAFT MOTORPLATE AND MIDPLATE
VFN SUNOCO HOOD EXTENDED TO WINDSHIELD
STRANGE MANUAL MASTER CYLINDER....THE BRAKES ARE PLUMB
PROPORTIONING VALVE
CONTROL LINE LOCK
THE CAR HAS BEEN WIRED BUT FOR THE LIGHT AND BRAKES ONLY...
SHUT OFF SWITCH IN THE BACK INSTALLED
