C5Z T56 (shorter gears than normal T56), clutch assembly, gear shifter, torque tube
Transmission grinds going into 1st gear. Doesn't grind going into 1st if car is taking off from a stand still and you go into 2nd then 1st. Probably needs to be serviced. Torque tube needs new input shaft and couplers. I have the stock clutch and a McLeod clutch and the McLeod is useless but some parts could be used off it, maybe. Also have the manual bell housing that goes with this.
Selling for $600 OBO for it all.
Some pics here. I'd post them but they're very large.
http://tinypic.com/useralbum.php?ua=...NMGRKC2Q%3D%3D
I also have the C5Z titanium mids for 300.
LOCAL PICK UP AND CASH ONLY
clutch
pilot bearing
clutch slave
manual harness
shifter ****
I know to go to auto I'd have to repin a few wires and reflash the computer to a auto file. So I'd think you'd have to do the same but to a manual file.
pilot bearing
clutch slave
manual harness
shifter ****
