cnc ported PRC ls3 heads
I have brand new PRC LS3 heads cnc ported. Never installed mocked up or anything. I changed plans for my build. Taking a loss at $1300. Get these at a real steal. Heads are complete except rockers. I can send pics via text.
here is a link to the heads
https://www.texas-speed.com/p-1179-p...ted-heads.aspx
832-633-3nine00
Thanks
Jonathan
832-633-3nine00
Thanks
Jonathan
I'll also ask for chamber volume and valve/springs info too since there were choices.
Did you look?
I did and have the same questions as above. As of right now the original post hasn't been edited, and the details aren't there. I seriously doubt TSP has changed the info on their website.
Here is the pertinent info on the link.
Completely Assembled and Milled to your Specifications
65-70cc Chambers
Are the heads on your turbo build chambered from 65-70cc or do you have a specific volume? The link isn't as informative as you imagined, is it?
65-70cc Chambers
I'll also ask for chamber volume and valve/springs info too since there were choices. Did you look? I did and have the same questions as above. As of right now the original post hasn't been edited, and the details aren't there. I seriously doubt TSP has changed the info on their website. Here is the pertinent info on the link. Completely Assembled and Milled to your Specifications 65-70cc Chambers Are the heads on your turbo build chambered from 65-70cc or do you have a specific volume? The link isn't as informative as you imagined, is it?
Not sure if it said what valves but I have had a few different sets of PRC ls3 heads and you have a few different valve options also.
