LS1/2/3/6/L76 Throttle cable bracket
Guys i had these made up using a CNC press brake and CNC laser. These are powder coated TEX2 to match the intake manifold. These fit every Throttle body I've seen and will accommodate big *** injectors too. I left the mounting holes a little big so you can move the bracket around to accommodate different injectors. It fits under the coil covers and uses your factory mounting hardware.
$25 shipped
$25 shipped
I've run maybe 3 versions of an aftermarket throttle bracket and none of them were ideal. The best I came across still causes the throttle cable to be too long for the throttle body cam, and the brace is too close to the intake manifold which causes it to interfere with the LS3 manifold noise cover... I had to trim off parts of the cover to allow it to fit. I know I can remove the cover, but I don't want to do so.
I'd like to see one which is gives better adjustability... elongated mounting holes so the cable slack can be removed, and a solution to keep the cable attachment bracket further away from the manifold regardless of how far back it's mounted in the elongated holes. And I'd want compatibility with the cruise control cable also.
Do you think those changes would be feasible, or is this intended to be a race-only part?
I've run maybe 3 versions of an aftermarket throttle bracket and none of them were ideal. The best I came across still causes the throttle cable to be too long for the throttle body cam, and the brace is too close to the intake manifold which causes it to interfere with the LS3 manifold noise cover... I had to trim off parts of the cover to allow it to fit. I know I can remove the cover, but I don't want to do so. I'd like to see one which is gives better adjustability... elongated mounting holes so the cable slack can be removed, and a solution to keep the cable attachment bracket further away from the manifold regardless of how far back it's mounted in the elongated holes. And I'd want compatibility with the cruise control cable also. Do you think those changes would be feasible, or is this intended to be a race-only part?
No plans on custom tailoring the brackets at this time. I've sold probably 75 of these and never had a single complaint though.
