racetronix fuel pump. NEW
Alright i bought this about 2 or 3 weeks ago for my 2001 camaro. Its brand new never opened . I decided to part my ways with the car and no longer need this. $200 shipped.
I have a New/Never Used, Racetronix 99-02 LS1 F-Body High Performance Fuel System (P/N F99-FPKG2) Which Includes the Following:
Fuel Pump Assmy for Plastic Tank Cars Only (P/N RX-F99-FPA):
Custom Racetronix/Walbro Pump
270L/Hr @ 43.5psi/235L/Hr @58 psi
Venturi Feed System
Red Anodized Billet Aluminum Pump Assembly
Racetronix to GM Teflon Wiring Harness
Hi Pressure Non-Kinking GM Fuel Tube
And the matching New/Never Used, Plug-and-Play Fuel Pump Power Harness for Plastic Tank Cars Only (P/N RX-F99-FPWHG-2):
Plug & Play (no soldering or crimping req'd)
Waterproof Delphi Weatherpack Connectors
Heavy 10 Gauge Stranded Copper Wire
Siemens/P&B 40A Mil. Spec. Waterproof Relay
Waterproof Delphi Fuse Holder w/SS Hardware
Direct Alternator Hookup for Max Voltage
All Connections Crimped & Soldered
Silicon Grease, Spare Fuse, Wire Ties Included
8Ga. Body Ground Upgrade w/Brass Battery Nut
![](http://i219.photobucket.com/albums/cc123/2001AntiVenom/th_100_0514.jpg)
Venturi Feed System
![](http://i219.photobucket.com/albums/cc123/2001AntiVenom/th_100_0515.jpg)
