Texas vs Tech
UT wins out.
Tech loses to OU but wins the rest of its games. This means OU, Tech, and UT each have identical records.
If memory serves, the next tie breaker is highest ranked team in the BCS is declared the winner, which would be OU, most likely.
So, OU could go to the Big 12 Championship.
OU loses to Missouri in the Big 12 Championship.
Missouri backs into a BCS game, OU likely gets an at-large BCS bid, and UT and Tech get to fighter over the Holiday and Cotton Bowls.
-Mike
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
-Mike
if tech is undefeated. You're out of your mind if you think penn states weak schedule even has a chance against techs sched.
