Any aluminum welders that can help me weld up a wheel?
Hey whats up guys, anyways im in need of a welder that can weld on aluminum. I have a CCW wheel that has stress fractures about 1 inch long and air is getting out and I need all ten of the fractures weldded up while I wait for a new wheel drum to come in. I have to put air up my tire twice a day and its my on daily driver
Let me know,
Roger
Let me know,
Roger
Let me know,
Roger
Let me know,
Roger
Go have the tire taken off, mask off the outside and inside of the rim with cardboard disks to keep over spray off and coat the inside of the rim with rubber undercoating. I read a popular hotrodding, or some gear head article about porosity in certain forged aluminum and cast wheels and this is a cheap and permanent solution. seals up any tiny holes where air can escape. I know you said your had cracks but hell if your still driving on it might as well stop it from leaking for now.
Thanks guys, im not looking at this as a final solution to my problem.... its more like a one to two week bandaid while the new wheel drum comes in from CCW. I don't have a spare tire and filling up a tire two to three time every day is driving me NUTS! As of now im running my BFG drags in the rear, one of my rear 335 wide 18by 11 1/2 in the front and the othere good wheel infront. I would of ran the drags infront but there too tall and the 335 is slowly rubbing on the inner plastic when I turn
i looked in the phone book and called up a welder for the same thing.. he did a great job completely grinding the entire crack out and built it up again with the rod.. sanded it smooth and polished it up. you'd never know.. i use them for my dragstrip tires. (nothing serious.. nitto 555's) it was a few years back and charged probably $60. but that was one crack..
