LMR Rear Mount 88mm Turbo Camaro Dyno Vid!!!
Here is a quick dyno vid of Longrange4u's rear mounted 88mm turbo camaro. This pull is on 15lbs of boost. Enjoy, I know Jared will.
http://www.youtube.com/watch?v=JWU33BxKckc
It is a 408ci shortblock with 6.0 heads and hydralic roller cam with a TH-400and 9in. Motor is a very simple setup. This car will be able to drive to the track, run mid 9's, then drive home. Killer street car!
taking in to account that that is a nice looking car and that rear mounts are easier to install and maybe not quite optimal but functional. Does the center grill piece come out or how is that intercooler geting any air? it looks like its getting about 30% or the air it should see. maybe a deflector under the nose with a kind v-mount style setup would work. just dont see how the intake temps arent high or how its performing effeciently. does it heat soak after a pull? it did however make good power. Just asking thats all
