Real Performance Motorsports (RPM) in Lewisville
If anyone has had worke done by RPM in Lewisville please let me know your thoughts (by PM is fine). I had a nice visit with them recently and learned alot about my options for a cam only swap on my '01 Z28 M6. They seem like good people.
I would also like to hear about any experience with the RPM5 and RPM4 spec cams and about the results folks have had running them on the street, at the track, etc. Thanks.
James
James
First off, you are going to get people that love them and people that hate them.
They have done most of the work on my car and I have been happy with everything so I recommend them. BTW, I have the RPM2 cam (specs in sig) and was pleasantly surprised at the numbers it makes.
I have had both RPM4 and RPM5. I enjoyed the RPM4. Very streetable. RPM4 made 383 rwhp and 400 tq in my bolt on/stalled(3600) cam only car.
I had an issue with the car, so let RPM do some work. RPM5 cam was put in at this time along with new lifters and oil pump. I drove the car for about 30 miles and the motor was starved of oil.
After tearing into the engine a buddy of mine confirmed the oil "o" ring caused the blockage. Spun 3 rod bearings.
Needless to say I havent done business with them since.
fixed all the fuckups from a previous shop for me. Haven't done me wrong and have made all the right moves to making more power while being very polite to someone who was a PITA in the beginning and before touching my car. I was a serious PITA to them.
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
Just saw another RPM cam install this week actually... They put a cam in a buddy's 6.0 chevy truck. Made good power and the truck drives very near stock after they tuned it. Good shop for you to take your car.
Didnt check PTV clearance and installed my cam a tooth advanced when they put a motor together for me and it cost me a WHOLE longblock. RPM CAN do good work but if something ***** up they WILL blame it all on you.
Pass this shop up. I have been to 3 shops in the DFW area HPP, RPM, and Quality. While i was happy with the tune HPP did for me I dont care for the owners much. Quality cant tune for **** either. MY next stop will be SQR
Are you the guy who took them a set of heads that had been milled and then the ptv issue occured? Thought I remembered a thread relating to such. I agree they can do good work, I just cant figure out why they made such a big screw up. Either way, it sucks that you lost a whole longblock.
Yeah, they had been milled .031 (double checked). RPM said they had been milled .050 and it was my fault because i told them the wrong number. Thats .020 off IF they were correct right? The cam they used was a 244/248 comp cam AND they flycut the pistons .090-.100. That cam is supposed to fit in a stock motor with no problems. The numbers they were saying just didnt add up to it being my fault.
When the motor went I took it apart to find that they had installed the cam a tooth advanced. Brian told me there is no way because he doubled checked that himself. How did he do that when it still had the same TTY crank bolt in it with the degree marks i made on it in the exact same place?
They are NOT stand up people. Anyone can get lucky once in awhile but they seem to have a problem with consistency.
I'm sure they do good work, but I'd avoid them just because of Pwebbz28's experience. Every shop screws up, the good shops are separated from the bad buy how they handle it. There's no excuse for a shop installing a cam a tooth off. If you're being paid to install a cam there is no excuse not to use a degree wheel and do it right.
I line up the dots in the garage and call it a day, but a pro should never do that.
Before a shop touches my cars I ask if they use a degree wheel and then ask them how they degree it. Before any of that happens I ask if they know how to check P to V and depending on these two answers, is if they get the work or not. I also ask if I can watch it happen on another car they are already that far into. I know how to work on my own ****, but I've got the time and money to pay someone else because my hands don't like getting dirty. If they dont even have a degree wheel or P to V checking tools in the shop, **** YOU! A squirrel will find a nut every once in awhile.
