1-2 shift issue
Old Jul 15, 2009 | 10:42 AM
Shackleford's Avatar
Default 1-2 shift issue
Occasionally, it seems like the 1-2 shift is a bit prematue and it feels like it jerks into gear kind of hard. Is this a bit ominous?
Old Jul 15, 2009 | 11:46 AM
camAro242's Avatar
mine does the same thing, i just try to baby it into 2nd when it happens
Old Jul 15, 2009 | 11:53 AM
That doesn't make any sense. It only happens after it's shifted into second. Sometimes it does it, sometimes it doesn't. It also doesn't matter if I'm babying it or not. It still does it if I'm just cruising very easily.
Old Jul 15, 2009 | 12:37 PM
twitchtwice's Avatar
is it when the tranny is cool or hot?
Old Jul 15, 2009 | 12:40 PM
rayosequis's Avatar
You may try posting this over in the auto tranny section, the guys over there are really helpful. Not sure about early shifting, but with a shifting problem it could be the 1-2 solenoid or accumulator. I am also having a problem with the 1-2 shift on my LT1 Vette and I think it to be a problem with the accumulator.
Old Jul 15, 2009 | 12:55 PM
Well, I especially noticed it this morning on my way to work, so I guess the transmission was still relatively cool. I have about a 30 minute commute to work.
I see. Is that an easy fix for a transmission shop? What would those parts cost?
Old Jul 15, 2009 | 04:33 PM
built408's Avatar
How many miles are on it? Stock? Tuned? What happens alot, is the 1-2 checkball will get stuck in the spacer plate, causing harsh shifts. Or it could be a binding 1-2 accumulator valve, or a broken 1-2 accumulator spring.
Old Jul 15, 2009 | 06:08 PM
138K miles. It was rebuilt a few years ago by the previous owner. Mods are listed in the sig. It has the stock tune. It only recently started doing this.
Should I take it to a transmission shop? I had this reputable guy in town rebuild the transmission in my old LT1 Z28. I bought a pro-built racing rebuild kit and he did the labor. How would they charge to replace what's wrong?
Old Jul 15, 2009 | 09:27 PM
rayosequis's Avatar
I've done the shift solenoids before, and they are very easy, just drop the pan, pull the pins and they come right out. I have not done the accumulator before, but it looks just as easy. If you have a guy you trust, have him put it on a scanner and road test it and maybe it will be something simple/inexpensive.
Old Jul 15, 2009 | 09:30 PM
My SES light came on today, but it was just for the stupid rear oxygen sensors that are going out. I just stopped by Autozone on the way home.
That's a job I'd rather pay someone else to do. lol.
Old Jul 16, 2009 | 09:34 AM
built408's Avatar
Not sure how much they would charge, probably around 100-300 just depending on the shop. Its really hard to narrow it down to one thing. They just need to pull the valve body off and inspect everything.
Old Jan 13, 2010 | 06:11 PM
Well, I got the transmission back last night. I bought this kit and the three options at the bottom. The labor was $750, and I got a rebuilt torque converter for $150. Sometimes, it seems like the same issue is still there. Sometimes, I get what feels like a premature 1-2 jerk when I'm not really getting on the accelerator. Other times when I'm going very easy on the accelerator there's a nice, smooth 1-2 shift. Should I take it back and have him look for something?
https://www.700r4l60e.com/store/prod...&cat=55&page=1
Old Jan 13, 2010 | 07:02 PM
indigo28's Avatar
sounds like you have shift kit to me
Old Jan 13, 2010 | 08:44 PM
Yeah. I do. I had one in my old '95 Z28. I suppose I have to get used to it again in the 1-2 shift. It seems like it starts to be a noticeably more firm shift around 2K. I guess I just wasn't expecting it.
Now, there's some kind of rattle going on under the hood, too. Also, I'm pouring coolant out everywhere, too. Right before I came in a few minutes ago, I tried to see if there was a burst hose, but I didn't see anything. Could a bad water pump make all that racket, the rattle I'm hearing?
Old Jan 15, 2010 | 01:09 AM
Jake_the_Snake's Avatar
the problem is usually caused by wear in what gm calls "the control valve body". basically it causes a harsh 1-2 shift, and often trips the p1870 engine code. this condition can be fixed by installing a shift kit, transgo # sk4l60e. my car has the same problem, and the code. been driving it like this for 9 months now with no real issues except it tries to spin out in the rain every now and then :/
Old Jan 15, 2010 | 10:37 AM
red281gt's Avatar
had same problem with mine , but mine will not go into 3 or 4th gear , they told me to change the shift solenoid , and that was not it , then the engine sensor? look at ur manuel for solenoids and u will find it . Mine was blown out replace it work for a while and then gave out again. Then I bought a built transmission and fix my issues lol ...
