Paging Wizeass
Mikey is saying, and has been saying for awhile that stock heads are just as good for boost as anything. As usual this is just dumb.
Prove me wrong
What you fail to comprehend in your "mathimatical" equation are a few things such as Boyle's Gas Law and adiabatic efficiency, which you blatantly disregard. This is really, REALLY basic stuff, so I would suggest you do some research before you come up with anymore bogus "mathimatical" equations. Try Corky Bell, for starters, since he explains this specifically.
Lets use engine dyno numbers for this example since those are real numbers.
(1) 370 cubic inch motor makes 500 na with stock heads.
(2) Same motor makes 750 with 7lbs of boost
(3) Add some heads ported by Nix (had to Brandon) to the NA combo and it adds 80 at the crank for a total of 580
(4) Same amount of boost will now make 820.
Now, please explain to me how heads dont make as big of a difference on a boosted motor please.
