Starter problem?
Old Aug 25, 2009 | 08:04 AM
Blackfly's Avatar
Default Starter problem?
Hopped in my wife's Suburban Z71, turned the key, everything came on normal (lights, radio, gauges etc.) and it "kinda" turned-over. (No ticking sound like the battery is dead)
I turned the ignition off then on again and had the same result. Then I turned the ignition one last time and left it on (as to force it to turn-over) it struggled and to no avail trukie-no-startie.
I can only guess starter (Damit Jim!...I'm a computer geek not a mechanic) Is there a way to troubleshoot this?
Option A:
I would like to try to fix this my-self, If I can get my fat *** under the truck
Option B:
Invite some peeps over for pizza and beer Saturday and have a car-fixn' party. Whoever replaces the part will get a little cash on top of the food and refreshments.
This is more reason why I need to hit the treadmill
Old Aug 25, 2009 | 10:14 AM
Super-Bat's Avatar
I would assume starter as well. I'm not sure on a suburban, but on my mom's silverado, it's pretty easy to get to. If you were closer, I'd help you out for some free pizza! haha.
(Btw- Do this on wednesday and you get a free pizza just showing up in your Camaro from Papa Johns.)
Old Aug 25, 2009 | 12:12 PM
Blackfly's Avatar
Thanks!
Could it be the fuel pump?
Old Aug 25, 2009 | 02:38 PM
twitchtwice's Avatar
i doubt its the fuel pump because if it was it would just crank forever i would assume. do those things have a volt gauge like the camaro?
Old Aug 25, 2009 | 07:48 PM
Blackfly's Avatar
Yes it does.
Old Aug 26, 2009 | 07:43 AM
Blackfly's Avatar
Going to remove the starter today when I get home from work...any pointers?
Old Aug 26, 2009 | 09:01 AM
well when you put the key in acc what volts does it show?
Old Aug 26, 2009 | 09:25 AM
Blackfly's Avatar
I will have to check when I get home.
Old Aug 26, 2009 | 02:19 PM
alright post up what you find.
Old Aug 26, 2009 | 02:53 PM
Super-Bat's Avatar
Make sure to disconnect the battery.
